anyone using pressure cooker ?
jimmyhaha
2,851
recommendation ?
I heard that it will blow up if u don't use it properly
and where can I find one with good price/performace ratio ?
thanks
Sciolist
255
I use a pressure cooker regularly. If you follow the instructions, they are quite safe. Make sure you don't exceed the recommmended volume, especially for foods that may foam (could block the vent pipe from releasing excess pressure).
Pressure cookers can significantly reduce cooking times, especially for foods that are cooked for long periods of time. I cook stews in my pressure cooker and get wonderful blending of flavors and tender meat. (Just be sure to add the more tender vegetables such as peas AFTER the pressure cooking step or they will cook into mush.) I also cook artichokes in the pressure cooker.
Presto is a good brand. I wouldn't go with a cheap one. Pressure cookers have the potential to be dangerous if poorly constructed. Even though the good quality ones are quite safe, I wouldn't to be working around a cheap high pressure vessel!
Stew recipe (all ratios are to personal taste so no measures are given): In bottom of open pressure cooker at med-high heat, heat cooking oil and brown cubes of meat. Add chopped onions at end of meat browning so they cook in what is left of the oil a little bit. Add water and chunks of potatos, carrots, other vegetables that you like in your stew (except tender vegetables which will be added later). Total volume should be no more than 3/4 of the pot size, and water should cover all the ingredients. Close pressure cooker lid according to directions, turn heat to high, wait until steam has been escaping from vent pipe for about a minute to make sure all the air inside the pressure cooker has evacuated and only steam is inside, then put pressure regulator on vent pipe. Start timing when pressure regulator is rocking steadily, cook for 20 minutes, cool until air vent falls indicating that pressure inside is low enough to safely remove lid. Remove lid, add tender vegetables and enough water/flour mix to thicken the stew. Add Kitchen Bouquet to taste.
boolerboy
178
the old kind of cookers had a chance of exploding. the new ones are very safe.
we have a couple of pressure cookers made by Fagor. it is a spanish company. they work great. the cookers drastically cut down on cooking time. and the food is healthy. we bought them online. i can't remember the web site anymore. we saved around $50 vs buying from Macys.
Jzero
18,834
Wow...people still use pressure cookers?
I'm impressed. I still do the crock pot thing.
jimmyhaha
2,851
my theory..
u want fastest PC with price/performace ratio..
so why not cooking..
still looking for good one w/ price/performace ratio
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,268
There are 3 generations of pressure cookers. Do your research on the web and AVOID the first gen ones. Second or third is ok.
Wallydraigle
Banned
Nov 27, 2000
10,754
Check garage sales too. I got an awesome pressure cooker for a quarter once. Even had the bobby thing that goes on top. A lot of times when the gasket wears out people just unload them real cheap at the garage sale, but you can get new gaskets at the hardware store, or even online. Usually $10 or less scores you a new gasket and the cooker is as good as new.
rgwalt
7,393
<< my theory..
Cooking Meth again jimmyhaha?
Ryan
boolerboy
178
jimmyhaha,
i did some research on pressure cookers before going with Fagor. It had good reviews at epinions and such, but wasn't as pricey as the cookers used by the pros. i paid $110 or so for a set of 2 cookers - two different sizes, that is. the set came with one pressure cooker lid and one glass lid. the cookers are made of stainless steel. the cooker's steam valve has two pressure settings and a quick steam release setting. i'll see if i can find where i got it from. its been a few months, so i don't think i still have the receipt.
there are some cookers made in india that are substantially cheaper than the european brands. i've seen some indian friends use them, but they don't even come close to the Fagors in quality.
don't get the cookers made from aluminium. stainless steel ones are the best.
Miss Vickie has some good info on pressure cookers.
lawaris
Banned
Jun 26, 2001
3,690
I use it quite regularly .
I use one of those advanced ones .....so there's no danger even when it overflows !!
It's worth the money to get a good one.
If u want something that is O.k> ( safe .......but .........) then asian stores will be having quite a lot.
I use FUTURA from Hawkins : see if u can find that in an Indian store.
shifrbv
981
I just bought a Farberware digital electric one on sale at Macy's. Paid $50 and it is worth every penny. I was afraid to get one of the traditional stove top ones because a friend of mine had one blow up on him while was cooking spaghetti. The spaghetti was all over the ceiling. With the electronic one, all I do is set the timer and walk away. I can even set it for delayed cooking if I need to prepare something then go somewhere. I can also use it to brown meats or steam vegetables which is nice. I would go with one of these because of it's ease of use vs. the stovetop kind that you have to watch all the time. I can have meats that taste like they've been slow-roasted in less than 20 minutes.
pcmodem
1,190
Yo,
Used to work with a woman that used a pressure cooker to cook carnitas (Mexican style marinated pork) and it came out quite well. So good that I almost bought a pressure cooker too.
-PCM
