Hello guys,
Does any of you using an Enermax PSU >= 350W and a Gigabyte 7VRXP Mobo experience a high frequency sound coming out from the PSU ???
I know its strange. I have an Enermax 350W with manual fan speed control. Even if my GA-7VRXP doesnt have anything on it but the power connector of the PSU + the power switch, the PSU makes a high frequency sound (almost similar to the sound a TV makes, but in the PSU's case its very auduble) about 15000 Hz which drives me crazy. Its volume depends on the CPU load as well. CPU load high, sound volume high.
I am almost positive its the combination of the two (this Mobo and the PSU) because if i change either the PSU or Mobo the sound is gone and everything normal.
I really need to know if there are some of you running Enermaxes on their GA-7VRX(P) because when i change the PSU i should know to demand another brand of PSU or just a higher (>350W) Enermax PSU.
Thank you.
Cheers,
BoG
P.S. Also if any one using a GA-7VRXP mobo and another brand of PSU than Enermax which DOESN'T make strange noises .. please let me know so i can decide which brand to choose for the new PSU.
Thank you.
Cheers,
BoG
