Anyone Using a Zalman ZM80A-HP on a Radeon 9700 Pro?
BoomAM
4,546
Its been done.
Ive seen Pre-OC`d 9700pros with the Zalmans as the cooler.
KH85
673
I do,
Mine is fine :) and is Overclocked :D.
If you are thinking of getting one i would get a 92mm or a 120mm fan to cool it down abit (just when in games) this is just to make sure it does not overheat.
Hope i helped
KHGamez
virtuamike
7,845
13
How do you attach a fan onto the heatsink? Do you just screw it on? Got a couple spare 92mm Panaflo's, was thinking about getting the Zalman and slapping a 92 on it.
KenAF
684
It doesn't need a fan on the heatsink. It's not meant to have a fan. There are no holes for a fan. All you need is a little airflow through your case.
I have a ZM80A-HP on a Radeon 9700 and it runs great--I don't have a fan on it, and don't even have an intake fan. Just one 120mm L1A fan running at 5v for exhaust in the back, plus the low speed 120mm fan in my power supply.
