Anyone using a SUN X7121A 21-inch monitor?
monolith1
40
I was going to buy one but I wanted to be sure that the screen was totally flat. Can anyone verify this?
splice
1,275
I hope you don't plan on using this for your PC. Sun does not use the 15-pin D-SUB connector. I believe there are converters out there, but I don't know how much they are. I don't know if I've used that model but all of the 21-inch Sun monitors I've used are pretty sweet.
monolith1
40
Thanks for the reply.
This monitor has both a 13W3F non detachable cable and HD15 input. So I would be able to connect this to my PC.
splice
1,275
Hey, that's pretty sweet. I would say go for it. How much do one of those thing run? I would love to have one and an UltraSPARC 10 :). The ones at school are damn nice.
monolith1
40
I won a bid on ebay for $437 shipped +tax. It's cool cause they're brand new direct from Sun. Anyway I thought it was a sweet deal cause now I can run my PC and my sparc off of one monitor. They 21 inch CRT that Sun is currently shipping is totally flat, this model is about 2 years old, and I wanted to be sure that it too was totally flat.
BudgetHT
20
I have that one you're talking about. I run my Ultra 5 through the 13W3 connector and my PCs through a switcher to the HD15 input. It's not completely flat like some of the newer monitors out there, but it's pretty damn sweet nonetheless.
Jason
MallowJr
Banned
Dec 20, 2000
801
word i laid down $650 for dell trinitron 21" monitr, using 1280X1024 @100hz as we speak.
and we do speak huh.
MallowJr
Banned
Dec 20, 2000
801
what do you mean "huh"? "will you please remove any loose items..change..holy gash! -play that funky music, yeeah-". lay down the cash for ze 21" Monitor, if you have enough deskroom to push it far enoughback - it's worth your heart in gold! And I do mean heart. I have apurpleheart..thats only cuz i have a purple shirt on!
squirrelman
869
I have a 21" sun trintron monitor myself. I dont know what suns code is but mine is the same as a sony GDM-500ps. Its a great monitor, but its not totally flat. It is alot flatter than a normal monitor though. It you have the same one I do, I think you will enjoy it. But just get some Chiropractor money ready because this things weights a ton.
