Anyone using a P4 3.06 GHz w/ stock fan/heatsink? What rpm are yo getting on the fan?
NeoReloaded
I just got mine, installed it, and the fan's cosntantly running @ 5400-5600 rpm and it's driving me crazy. I'd probably get used to, but I've heard from other people that their fan runs @ around 2500-4000 rpm (variable based upon temp's). Now I'm really worried I installed my heatsink wrong or the thermal paste wrong and am now stuck with a 5600 rpm screamer. My CPU temp according to the BIOS ranges from 39 - 42 degrees Celsius, and is 36 degrees Celsius according to MBM 5 when in Windows. MBM 5 reports the motherboard is also 36 degrees Celsius.
And if that is abnormal, how can I fix it? I mean, what's a good process for removing the heatsink and cleaning it and the CPU, and then how should I add more thermal paste (and which brand)? This was my first time working with thermal paste (always had thermal padded ones) and I've obviously screwed it up beyond belief...
Jojo1971
2,200
yes it's very noisy... you can use a potentiometer/ or use 7 volts to reduce it's rpm..
