Anyone using a BELKIN WIFI Router?? Help with Encryption!
iamme
21,058
I can't seem to get encryption working on the router. Not sure if it's a problem w/ my router or PC Card (Orinoco Gold). When I enable encryption (I've tried 64 bit and 128 bit), I can't access the internet on my laptop. With encryption off, it works fine.
Any clues?
BTW, I've updated the firmware on the PC Card and router to the latest ones and I'm using WinXP Home on my lappy.
theanimala
330
Can you still access the router's config screen from your laptop? Can you wire up to the router and get out through there?
iamme
21,058
I can't get to my router's config screen. My desktop is wired to the router and has no problem with or without encryption.
