Anyone Use Sound Deadeners?
MonstaThrilla
1,652
2CoolTek sells some Neoprene sound deadener. Does this material work? My aluminum Lian-Li is pretty friggin' loud, and I didn't even add any external fans yet. The disc drives are loud as hell too (Aopen Slot DVD and a Plexwriter), being that they spin at 40x when reading CDs.
NEWKILLA
3,589
guys get B-QUIET,ive been using this stuff in some test rigs and it rocks
the only thing better is the cork boards, but IMO it looks like crap
i ll post a link when i find the public site,i only have the distributer link
which is phone numbers,
KILLLA
May 31, 2000
75
I was gonna use some old mousepads and line the inside of the case with those.
Any kind of dense foam or rubber would work I believe..
Glow
331
oh yeah, and how much would I need? I am in need of shutting up my delta fan...they only seem to sell it in huge ass sheets made for cars.
GiZzO
1,789
They need a FAQ for this...
Sound deadeners such as dynamat, b-quiet, asphalt, vinyl. Really do nothing for you within a computer case. There main purpose it so add wieght around a certain area in effect reducing vibration. I see ppl lining up there doors with it which a waste of money, its not designed for soaking up airborn noise, its design to reduce the noise before its created..vibration. If you were to use it you would only need to use in a few spots around HD, or fans, but you can practicly achive the same thing by using rubber gromets or rubber washers, without the mess and unnessary wieght. For a test put your hand over a peice of sheet metal where you think vibration is, what you get by putting a little wiehgt on that peice of metal is basicly what a sound deadener does for you.
For noise from a spining harddrive, loud fans and such, you would need something that would soak up the noise on impact, such as an acoustical foam. Somewhat opposite of a sound deadener because its light wieght and doesn't reduce vibration, most sound deadeners reflect sound, ex: concreate parking lot (dynamat concreate/lead based). In something like a car door and floor panels, where you would want both worlds you would slap on the sound deadener first, multiple layers if wanted, then you put acoutical foam on top of that.
Its funny to see ppl line up there case in sound deadeners, and be all pissed it does nothing, no sh|t retard..do ppl read instructions anymore? what a mess what a waste.
salman327
788
Yeah I would love some accoustical foam to line my case w/ and shut up a delta black label
RustyNale
2,220
I just lined my Enlight 7237 with 1/8" cork and cut the noise down almost to "stock" noise levels with 6 fans going. 92mm in front, 80mm in a top blowhole, 80mm on the cpu, stock fan in the psu, stock fan on the northbridge, and a 40mm on the video card.
