anyone use PCIE 6 pin adapter to 4 pin molex convertor?
poohbear
2,284
hey all, im upgrading from an AGP 6800gt to a PCIE x1900xtx, and while i have a sturdy enermax 460wt psu with 33a on the +12v line, it doesnt have any of the newer PCIE connectors. can i use one of these convertors:
http://www.directron.com/6pinpcie.html
i cant tell if im supposed to connect both 4 pin molex connectors to the 6 pin PCIE adapter or just use one? is there a general problem w/ using these convertors, or will i be fine?
thanks in advance. :)
lopri
13,317
691
If you look into the 4-pin molex in the adapter, you will notice that there are 3 lines on each. 3 + 3 = 6. So you connect both, then connect the other end to the video card. It's always a good idea to have each 4-pin molex connected to different rails from the PSU.
lyssword
5,630
25
by the way, the retail video card box should include that 6pin adapter, but if you go oem, then buy that $10 adapter :) To be sure check the description of what is included..
Lonyo
21,938
I'm using one with my 7800GT (it came with the card). Yes, you are supposed to hook up 2 4-pins to it.
jiffylube1024
7,430
You connect both.
When plugging in the Molex connectors, try to trace back the molex connectors to the PSU and use two 4-pin molex plugs from DIFFERENT wires (eg don't use just 2 molex connectors from the same line).
