There's a new thread today here on this forum about how quiet some retail PCs are (Dell, et al.). The issue of noise vis-a-vis active and passive CPU cooling came up as a result. I posted a semi-related question several days ago about CPU cooling ducts. Unfortunately, that thread got sidetracked and I never did really get an answer. :-(
Anyway, I was wondering if anyone here has ever tested CPU temps with active vs. passive cooling. In other words, active as in a heatsink/fan combo cooling the CPU, and passive as in one of those plastic ducts over the CPU/heatsink [w/no HS fan] that acts like a vacuum and merely sucks hot air away from the CPU and channels it to an exit fan (sometimes via a sealed tube).
Member Cerb mentioned something to the effect of passive schemes like this resulting in temps running "20 C" hotter than active schemes with a heatsink fan. As far as I know though, I've never heard of Dell having any problems with machines dying early due to constant excessive heat (in fact, system longevity is one of Dell's known attributes, isn't it?).
Has anyone ever done a test with both methods on a particular CPU to see which really results in lower CPU temps?
Just curious.
Ken
PS: Before you ask, I don't work in the computer biz and don't have test equipment. If I did, yes, I'd do the testing myself!
Just curious.
Ken
