Anyone running GeForce 4 Ti with K7S5A?
howardthehobo
Banned
Mar 18, 2001
664
Is there enough space to mount GeForce4 Ti on this motherboard? Because GeForce4 Ti is so HUGE and I am afraid that there is no enough space for it.
Any information would be very appreciated.
Thank you for your time,
Howard
mantis69666
157
Not yet. But hopefully I will be within the week, so long as I can get my hands on a Leadtek Ti4600. Let me know if you find out problems first.
CHHASmatroxuser
299
I'm using a Voodoo5 5500 AGP in mine at the moment, and it's a tight fit.
The end of the card is right on top of the IDE connectors, I had to apply a bit of the old ultra-violence to the IDE cables before I could seat the card properly.
howardthehobo
Banned
Mar 18, 2001
664
Thank you for the information, CHHASmatroxuser
Actually, the capacitors on the GeForce 4 Ti are what I am worrying about, it looks like you won't be able to mount the video card on K7S5A properly because the capacitors on the GF4 are too big.......
Howard
artemedes
778
I am running a PNY ti 4400 and it is a tight fit, but goes on without any major problems. If you are using oddball IDE cables you may
have to get some that are flatter (connectors). I think the capacitor situation is only for epox 8kha users, and it is reported that
visiontek might even have changed their design so that it is not an issue.
I am using the cables that came with my k7s5a and had no problems, even though it is a tight fit.
Boogak
3,302
Yup, got a PNY Ti 4400 on my K7S5A mobo too. A little cramped, but it all fits and works great!
howardthehobo
Banned
Mar 18, 2001
664
Hi, Boogak. Thanks for the information. I got a question for you, how is the 2d of PNY GF4 Ti 4400?
Howard
artemedes
778
I am not Boogak, but I'll reply anyway. I have two computers hooked to a kvm switch, my other is a matrox g450 which is supposed to have excellent 2d
and I had a Radeon LE in before this. I am very hard pressed to tell the difference in the 2d between any of them. I usually have my desktop
at 1152X whatever and all 3 looked great.
My monitor really doesn't do well above 1280 for 2d stuff, Even my matrox starts to look fuzzy there and above, so I really shouldn't comment on
really high resolutions.
I have been running all my games at either 1280X1024 and 1600X1200, something I would have never done with the radeon LE.
