Well, for practical max I use 10% above the rated voltage. For my Celeron I am WAAAAYYYYYYYY above the limit, since I'm running 27% above the rated voltage. 😛 (1.5 V x 127% = 1.9 V)
On the other hand, the 1.13 GHz chips are rated at 1.8 V so 10% over that is 1.98 V. :Q I know, I know, the 1.13 GHz chips don't work properly. OK, the 933 and 1000 MHz chips are rated at 1.7 V so 10% over that is 1.87 V. So, yes, 1.9 V is really pushing it but if you have good cooling it should probably be OK. However, I don't recommend more than 1.8 V to anyone, and I still may drop down to 1.8 since my computer is at 100% load 24/7.
By the way, you PIII owners: ALL Celeron II chips are cB0 stepping. 😉
