anyone own an InWin S500 case and added a rear case fan?
raystorm
4,712
Like the title says.. I own an InWin S500 case and would like to install a fan that would go in back of the case. But I dont really know which one to get (this is my first self built pc so I really dont know much about case cooling). Which fan (model..etc..) did you install and where did you buy it? I assume that the rear case fan would blow air OUT of the case right?? Please suggest a specific model if you can.
Also, I'm plan on getting a geforce 3 soon and may overclock it. Are those fans that go into a first pci slot worth buying?? I figure they would be useful in cooling the video card if I decide to overclock it.
thanks to anyone who replies..its appreciated :)
Grendel99
888
An 80 mm fan should fit. I have some 80mm Panaflo's L1A's. They are very quiet, and push a decent amount of air. If noise is a concern, I suggest you get that. If it isn't, check out 2cooltek and look at there fans. Sunons, Panaflos, and YSTech fans are all good. Just look at the Db and CFM ratings....
Oh yeah, and yes it should be blowing OUT of the case.
