Anyone Know where I can get replacement floppy power plugs for the power supply?
Texaco28
I can get the larger harddrive replacement plugs at directron.com but they don't have the floppy ones. Just the connectors themselves without wires.
I dont have any floppies in my pc. I had removed all the extra cables from my ps and i'm getting a raedon 9700 and iI need a floppy connector to power it and I like to do a good job with my wiring.
Lol, just splice and tape together the wires, it's clean, simple, and you can save yourself some money. I doubt anyone sells floppy connectors heads anymore, since they aren't the most popular thing as of now. I doubt the radeon 9700 uses floppy drive connectors, it, if it uses any at all, uses this. Even if it does use that, it should come with it, since ATI would probably want to make it as simple as possible for the buyer to use it.
