Anyone know where I can get parts for a lawnmower engine.
Ktulu
4,354
I was mowing the lawn over the weekend and completely missed a skateboard wheel in the tall grass. Anyways, it got caught in the blades and seized the engine. After trying to crank it, I noticed large amounts of smoke and some oil coming from the exhaust. I want to give it a try and repair it myself but have no idea where to get parts from. I'd prefer a B&M store but online would do too. Any suggestions, it's a Briggs ans Stratton if that helps.
yelo333
990
Disclaimer: I'm NOT a mechanic, and am far less knowledgeable than most here. I'm just a computer geek that happens to own a mower. :)
Anyway, I have had my mower smoke after starting it again after running over things that sieze it up (rope, plastic tubing, etc). But it always returned to normal after a second or so of sputtering. You did let it try to run for more than a second, right?
This site may have some helpful info:
http://www.kichline.com/chuck/fixit/mowers/default.htm
Demon-Xanth
20,551
Many places like True Value have service departments for light equipment and will have parts.
Demon-Xanth
20,551
http://www.briggsandstratton.c...ce=10&searchCountry=US
CHINO MOWER & ENGINE SERVICE
13546-A CENTRAL AVENUE
CHINO, CA 917105105
1 EVAN'S LAWNMOWER SERVICE 436 WEST MONTEREY
POMONA, CA 917683712 (909)629-8234 1.09 Miles View Map
2 LARRY'S LAWNMOWER SHOP 244 WEST HOLT AVENUE
POMONA, CA 917683103 (909)629-0990 1.21 Miles View Map
3 MISSION LAWNMOWER CENTER 1236 E MISSION BLVD
POMONA, CA 917662217 (909)620-8211 1.38 Miles View Map
4 A A EQUIPMENT 4811 BROOKS STREET
MONTCLAIR, CA 91763 (909)626-8586 3.21 Miles View Map
5 CENTRAL MOWER SERVICE 5120 B SCHAEFER AVENUE
CHINO, CA 91710 (909)627-1210 4.34 Miles View Map
6 CHINO MOWER & ENGINE SERVICE 13546-A CENTRAL AVENUE
CHINO, CA 917105105 (909)627-2384 4.46 Miles View Map
7 LA VERNE LAWNMOWER CENTER 1300 W BONITA AVENUE
LA VERNE, CA 91750 (909)596-2363 4.60 Miles View Map
8 FOOTHILL LAWNMOWER 8133 FOOTHILL BLVD
RANCHO CUCAMONGA, CA 917303104 (909)982-1863 8.30 Miles View Map
9 MOUNTAIN VIEW SMALL ENGINE 9593 9TH STREET
RANCHO CUCAMONGA, CA 917304511
(based on pomona, ca in your profile)
Ktulu
4,354
CHINO, CA 917105105
Hm, I wonder if any of those actually sell the parts or will just service the engine. I was kind of hoping of doing it myself.
Ktulu
4,354
Yeah I did try to keep it on but once it turned off on it's own it wouldn't turn back on, no matter what I tried.
Demon-Xanth
20,551
They sell parts.
bruceb
8,874
111
You can buy the parts. But if it seized, you need a new block, piston, rings,
and maybe the connecting rod. And you don't just throw them in. You need
to check clearances and torque the bolts properly. Toss in a gasket set as
well. You may have even damaged the crankshaft. The 2 most costly parts
will be the crankshaft and the part of the block where the piston goes up and
down (if you can get that section without the whole block) .. it would help to
know the MAKE & exact Model # of the motor .. Briggs, Techumseh or whatever.
Then parts can be looked up. As I said earlier, faster, easier, cheaper & comes
with a Warranty to just buy a replacement motor. You can install it yourself in
about 2 hours
