Anyone know where I can find a replacement Fan for my 9700Pro?
BD231
10,568
138
Little P.O.S. died on me today, cards fine but naturally it can't do it's job without this 30 cent part :|. Anyone know where I can find a fan for it?
ethebubbeth
1,740
Nearly any hardware site you go to will have some sort of radeon gpu cooler. From what I hear i'd stay away from the thermaltake orb coolers though.
try newegg.com, xoxide.com, case-mod.com, or the like and see if you find something decent.
BD231
10,568
138
Don't see a point in droping cash into a whole new heatsink when the one on the card is just fine, just want a new fan.
ChefJoe
2,506
They're usu. pretty tricky to replace... because each manufacturer uses a different specialized HS design... some have fans without outer cases, others look like you could just snap in a 40 mm fan and go.
Have you considered a bracket and 80mm fan directed at the GPU heatsink ? http://www.svc.com/zafbfanbras1.html
Davegod
2,874
try just emailing the manufacturer, should send a replacement out to you - at worst want you to RMA it for repair.
