anyone know the power draw for a 9800pro?
Boonesmi
14,448
does anyone know how much power a 9800pro requires? more specifically im trying to find out how many amps of each of the 3.3v, 5v. and 12v rails
**** edited to add *****
tks for the replys... but im not worried about a powersupply not being enough.
i was curious of the powerdraw of several different components... everything i was easily able to google up the info for everything except for the 9800pro
Munky
9,372
I know I ran an OC'd Athlon XP and an OC'd 9800p using a generic 300W PSU with 18A on the 12v rail, so it doesnt require much power.
BassBomb
8,390
my friend has had trouble running 3hds 2 optical + amd 3500+ (130nm) with his 9800 PRO
Boonesmi
14,448
i was curious of the powerdraw of several different components... everything i was easily able to google up the info except for the 9800pro
luigionlsd
256
A friend of mine has a Dimension 8300 with a 230-250 watt power supply, and the card ran fine on it, if that helps you at all!
