Anyone know of sites for automotive help?
Semper Fi
1,873
I'm looking for how-to sites or good resource sites for domestic cars. Specifically '97 Ford Taurus.
So far I haven't found any good ones. I bought the book from Autozone, but it's not specific enough.
Thanks.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Can you be more specific than "the book from Autozone"? If by that you mean the Haynes manual, then I don't have any advice for you other than to say that you could probably order the factory workshop manuals from Ford if you intended to work on the car yourself a lot.
Zenmervolt
Semper Fi
1,873
I'm looking for a website, the book is irrelevant, disregard reference to said book.
Thanks anyhow. :)
