Anyone know how to replace fuse on z560s? i broke my 2nd pair
NuclearFusi0n
7,028
<< ...as confirmed by reviews. >>
How's a side by side comparison in the same room?
NuclearFusi0n
7,028
<< i can keep the bass knob down all i want, but i dont think its gonna help till i learn how to replace thisfuse >>
The power switch on the back of the amp/sub is the fuse...unscrew it
Phuz
4,349
Look at all the Klipsh owners coming in to bad mouth the Z560s. Obviously they feel threatened or were questioning their overpriced systems.
Both speakers are excellent. I believe Logitech has some quality control issues, but otherwise, they are excellent.
I think the Klipsh people are the ones who need to question their methods, paying up to ($650+ CDN) for a pair of speakers with PLASTIC cabs? Come on.
Anyone with a real appreciation for sound would get a component system with wooden cabs are even make their own.
The Z560s are justifyable because of their price, and power. Considering their sound is on par with the Promedias, the Klipsh's are not.
limsandy
1,554
<< i can keep the bass knob down all i want, but i dont think its gonna help till i learn how to replace this fuse >>
CHASEM, my first Z-560 also blew its fuse. But then I bought it from dell.com and I request for RMA. But then I forgot to send the defect unit back to dell.com
So I have 2 Z-560s, one working and one defective. I have been trying to make a 6.1 set up for a while. But I cant seem to find anyone who can teach me that.
BTW, the fuse is on the sub-woofer so, when i said defective, I mean the sub is not working. The satellite should work fine.
So, is there anyone out there who can tell me how to make a 6.1 set up with Hercules GTXP ?
tigerbait
5,155
<< But then I bought it from dell.com and I request for RMA. But then I forgot to send the defect unit back to dell.com >>
sweet... they never said anything?
<---- hurries to "RMA" his Z560 back to Dell :p
PsychoAndy
10,735
LOL that's freaking great!
On a side note, where did all the klipsch fanboys go?
RGN
6,623
I push min HARD and I have not had a problem. I think that I would have been crazy to spend twice as much on the Klipsch.
Valhalla1
8,678
dont skimp on speakers... logitech? ehh, no thanks.. Klipsch owner here, I have my original 4.00 promedia's, and I crank the sh.it out of them every day.. no problems at all
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
<< dont skimp on speakers... logitech? ehh, no thanks.. Klipsch owner here, I have my original 4.00 promedia's, and I crank the sh.it out of them every day.. no problems at all >>
:D
silent tone
Unless there is an additional internal fuse, the external one is between the remote control cable and power cable. It's a 4 amp 250 volt, slow burn fuse.
chasem
Banned
Dec 17, 2001
705
i KNow, i SEE the switch, I just dont know how to get the fuse out, thats all i need to know
silent tone
Stick a flat-head screwdriver into the slot apply a little pressure and twist. It'll release and slide straight out.
limsandy
1,554
ya, at first I thought they were gonna charge me twice for the 2 Z560s but they didnt.
chasem
Banned
Dec 17, 2001
705
okay guys, im so close i can taste it,
I pushed the switch all the way in. now i spent 30 minutes undoing all the screws, im looking at the switch i need to get the fuse outta
What 'Slot' do i stick the screwdriver in. i see no slot, i can put it where the auctualy switch's base is, is that right
chasem
Banned
Dec 17, 2001
705
okay, this thread has been going for 3 days and no one can be more specific than,
'Put the screwdriver in the switch and turn"?
I can not turn the switch any, ill paypal someone 1$ if they take a pic of showing how to do it
BD2003
Not all of the Z560s have the fuse on the outside. Sounds like youre one of the unlucky ones. Send it in. Dont void your by trying to open the box, because a simple fuse switch just didnt fix it for me.
BD2003
I dont think anyone can tell a thing from that picture.
Its pretty simple dude. Find the fuse. If its blown, replace it.
chasem
Banned
Dec 17, 2001
705
dood, that is a picture of the switch when i took the back cover off, is the fuse in that?
I cant get the fuse out
BD2003
Youre obviously not a technician. If you havent found it by now, stop looking before you electrocute yourself.
If its a circuit breaker (which I doubt), just flip the switch. I have one of the sets where there's a little box that pops out that contains the fuse You dont, and thats why youre getting confused.
Its likely near the power cable. Its a small glass tube, with metal ends.
