- Nov 30, 2000
- 3,371
- 0
- 76
I'm taking General Chemistry II. I've never had Chemistry before, but for some reason my advisor thought it would be a good idea to jump into Chem II instead of taking Chem I first.
Anyway, we did an experiment in lab and in the post lab report I'm supposed to calculate a few things that I do not know how to calculate.
Basic Lab procedure:
I took 0.5496 grams of Aluminum Foil and dissolved it in 35 mL of 2M KOH.
I then filtered the liquid, keeping the liquid, and rinsing with 10mL of DI water.
Added 10 drops of methyl red.
Iced the liquid.
Then, I heated the liquid while stirring and adding 8-9 mL of 6M H2SO4 (the numbers should be subscripts)
Did this until it turned a clear red color.
Cooled the liquid and filtered it again
This time we kept the crystals - which are supposed to be Aluminum Crystals.
Final weight was 1.0678 grams of crystals.
Questions:
1. Calculate moles of Al used.
2. Theoretical yield of moles of Al.
3. Theoretical yield of grams of Al.
I think I know how to convert from grams to moles so, if I can get someone to explain how to do number 1 and 2 (or 3), it would help me a lot.
Any help would be appreciated.
I'm not asking that you work it for me, but if you can help me with equations or explanations, it would be greatly appreciated.
Iced the liquid.
Questions:
