Anyone know a DIY to remove a door/doorway and put a wall
TheSiege
3,918
14
i cant find it any where. anyone ever do it?
take a door/doorway out and fill it in to make a complete wall?
iamwiz82
30,772
13
Remove the door and all of it's hardware and trim.
Put in a stud between the floor and header
Put up drywall
That's it in a nutshell. You could also remove the header and short studs and replace them with full studs, but that is a lot of work and really doesn't add anything.
Juno
12,574
Put up drywall
beat me to it.
cardiac
14
I did the same thing in our kitchen. We had a small galley kitchen in our house, along with a decent sized seperate dining room. I knocked out the wall (Non load bearing) between the kitchen and the dining area and made it one room. Then took the trim off the kitchen doorway, put in 2 vertical studs (To keep the 16" on center layout) and drywalled the kitchen side. Put up a nice 32" wall cabinet to add to the kitchen storage. On the side that faced the living room, I added some recessed shadow boxes made out of 1x4" pine attached to the new studs and then drywalled around it. The wife loved having the recessed knick knack areas.
Was pretty easy to do, and I have only average carpentry knowledge/skills.
Bob
NoShangriLa
1,652
Put up drywall
Remove the frame if the frame protrude beyond the wall stud or prevent new drywall to lay flush with the old wall.
Nail new shoe, plate, and additional 2 studs at the sides of the frame to provide nailing surface for new drywall. Additional studs should be place at 16" center because of insulation standard, however you can place it at any interval as you please (24" center is some what common in older construction).
Old & new drywall edges can be bevel to prevent raise/bump above existing wall when tape & mud.
Or, carve/cut a thin paper surface strip off the old drywall and then cut the newer drywall and leaving a thin strip of paper over lap the old drywall shaved off surface. (This method doesn't require taping when mudding.)
Outside wall tend to be finish off with 5/8" OSB or plywood then tar paper over the surface then mesh/stuco or siding.
Good luck!
