- Feb 14, 2004
- 51,937
- 7,408
- 136
The 12V jack in all of my cars is down near the gear shifter, so I have to snake a long Micro-USB cable up to the windshield to power the GPS devices. I was thinking about integrating a USB port into the dashboard, so I could just run a short 6 or 12" cable up to the GPS - less mess, more convenient. Clarion makes a hole-mount extension cable with a cover:
http://www.amazon.com/Clarion-CCAUSB...dp/B001GXQMXE/
Garmin also has a 12V hardwire kit, although then the cable would just be hanging out:
http://www.amazon.com/Garmin-Hardwir.../dp/B001M09L20
Anyone do this before? Ideally I'd like a 12V brick to USB male (then add on the Clarion piece, or even better, a 12V brick to hole-mount USB female, but I haven't come across something like that yet. That way if I switch out devices (cell phone, GPS, whatever) I can swap cables to a 30-pin, Micro-USB, etc., and also not be stuck if the Micro-USB connector breaks.
