purbeast0
I hooked mine up last night, and we only have 1 phone jack in our apartment. It's in the bedroom and my main PC is in the other room. There is a wall between the PC and the router, and it's about 25 feet or so physically away.
I went to the store yesterday and purchased linksys wireless PCI card for my PC. It was like $50 at compusa. Since my linksys router is fine I figured the card would be too.
However I installed it and the connection seems to be dropping out constantly or disconnecting for seconds then connecting again. Sometimes it takes a while to load webpages and it will just try to load one and hang, then I will have to refresh it to get it to load again.
Also when downloading stuff, someitmes it'll be real good at like 350Kb/sec downloading, then it'll just drop off to like 5Kb/sec and then to 0 for a few seconds, then go back up.
Is all this common? I'm wondering if this is a problem with the router they give you and that maybe it's a crappy router. Can you hook up your own router to their router and use that instead? Would that make a big difference or is this all just part of wireless connections.
