Anyone here have carbon fiber re-painted?
alkemyst
83,769
19
Ok you want a black and white answer.yes they will be able to repair it properly and.have it.look orginal.ive painted CF hoods with the sides painted and the middle remained CF. None of my customers were unhappy but if they were i would sand the paint and clear back with a fine grit retape correctly and repaint and reclear having it look orginal and the correct way the.customer wanted. So issues or flaws with the cf
So have you done this or guessing it would come out fine?
Sep 7, 2009
12,960
I have no idea what any of this has to do with my question.
It's him trying to help you, Alky. He's saying that if this is an aftermarket part then what's the issue with putting the stock part on and leaving them the aftermarket piece.
In my opinion you've gotten a lot of good advice and you could be a lot less shitty to people about it.
alkemyst
83,769
19
Either way there is refinishing involved...how do you wait for that? It's not helpful when people don't understand WTF they are answering.
There have been only guesses...
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
118
Wait for re&re, you know REMOVAL AND RE-INSTALL. All you had to do was ask if you did not understand what re&re meant.
Sep 7, 2009
12,960
You are so disrespectful, why do you even come here?
It's extremely clear that you place no value on anyone's advice or opinions in this forum, you'd be a better fit at your local ricer forums where they'll just tell you what you want to hear about adding your CF parts - no matter how misguided.
alkemyst
83,769
19
I have already asked you not to respond to my threads. It's clear you can't even get E36 vs E46's straight, don't know much about M's at all...your posts are simply troll fodder hoping to rev up people into flaming attacks.
Quite simply I wanted to know about repainting this piece. Not about how I should demand a refund, return it, etc.
This was an example of people feeling the need to put two cents into my threads without actually having any change.
If you feel this way, like I have said; skip my posts. I can tell you right now, I know 100% there is nothing you could ever answer for me that I wouldn't already know.
alkemyst
83,769
19
I know what it means, it doesn't answer my question.
This is an example that you do in many of my threads. I ask one question and you provide the answers to other unrelated questions.
jlee
48,517
223
That's probably the most qualified answer you're going to get. If a professional body shop guy's answer isn't good enough for you, I would suggest you seek help from another source than the internet.
JCH13
4,981
66
Black2NA owns his own body shop and does quality work. You are getting professional advice.
Black2na
629
My almost 10 years of doing body work allows me to KNOW how it would come out if a professional did it. ive have honestly tried to help you but at this point i honestly have no idea the answer you are thinking you need....
3chordcharlie
9,859
Is this part on an M3?
Because that would change everything:p
They offered to replace it - take them up on it. At least in the end, it will be 'right'.
hanoverphist
9,867
23
and heres another opinion from a former industrial painter. yes, it will look fine, if the painter is a good painter. blending the clear isnt too terribly hard, so it shouldnt be a big deal. id be more worried about the paint coming completely out of the CF, which isnt really that hard to do either.
id still say wait for the replacement if the shop is willing to buy you a new one.
AMCRambler
7,706
28
I don't think he realizes that the carbon fiber is shellacked together inside resin. So essentially you've got the carbon cloth, then resin, then paint, then clear coat. They will sand down the clear and the paint. The resin will still be there between the cloth and their sander. They will not damage the part unless they're idiots and sand through 1/8th of an inch of resin.
alkemyst
83,769
19
No, I do realize there is a resin layer.
SyndromeOCZ
615
The resin wont hold up to the UV rays from the sun. So they clear coat it with a urethane clear coat(which is called Automotive Clear Coat) to protect it from the harsh UV rays. If you sand the resin down to a nice consistent clean/smooth piece then give it 2 or 3 good coats of urethane it will look perfect and will last for years.
