Anyone having trouble using mushkin promo build pc3200 (2-2-2 rated) @200mhz fsb?
Anonemous
7,361
I was just glancing through the forums at amdforums and noted that some ppl were having trouble running the promo build (rated 2-2-2 @200mhz) at 200 mhz in sync with their cpus. I noticed that I also had the same problems as they described. I had stability issues (p95 erroring/3dmark2k1) when I set the fsb higher than 180 even @ low multiplier speeds (9) with increased vdimm/vcore. So did anyone get their systems to be stable @200 mhz in sync with the ram with the 2-2-2 timings?
