BarkingGhostar
- Nov 20, 2009
- 8,409
- 1,617
- 136
Wait, did both of you actually go do work on the ISS at one point? That's awesome.
are you talking about solarcity?
my friend was thinking about getting them installed.
A friend used SolarCity. He says they're leasing and saving $50/mo. and get a tax rebate from the state at the end of the year.
Personally our electric bill is about $130 and we have very high rates here. But leasing at something like $65 does not make a big enough difference imo.
One other thing - I was told that the panels must be on the south-facing roof here in the northeast. If that's true, that's the front of our house and it's just plain ugly that way.
Hahaha yeah pretty much this.
I always think it would be cool to go solar, then I remember, we don't get enough sun to make it worthwhile.
Now if we could find a way to convert snow into energy...
I found "Solar Power Your Home for Dummies" to be pretty informative when I read it about a year ago.
http://www.amazon.com/Solar-Power-Yo.../dp/0470596783
Only $10 on Kindle.
Also (and perhaps more important from a physics standpoint), a quantum field theory (at least those that seem to match our real world) quickly reaches infinity if distances become too small. To see how these infinities can arise, consider both the fact that electromagnetic forces get larger at small distances (infinitely larger at infinitely small distances) and also the distance and momentum relationship from the uncertainty principle of quantum mechanics.
No, batteries are not needed. Your appliances don't turn on and off. The inverter is in phase with the line coming into your house.
I think an easy analogy is with water. Imagine you're hooked up to the city's water supply. And, you drill a well and put in a water pump in your basement. Let's say that at time A, you're using 10 gallons per minute (LOL) in the shower, but your well pump is only providing 9 gallons per minute. The city water will pump 1 gallon per minute in, which you will be billed for. Let's say at time B, you're using 5 gallons per minute, and your well is pumping 7 gallons per minute. Your extra 2 gallons per minute flow out of your house into the city water system, and your meter "runs backwards." But, the water from the city and water from your well is identical. Your shower can't tell the difference, nor can it tell the difference which source it came from. (There are two different types of metering in this case, some that do, more or less, run backward, and some systems have separate meters for the amount that goes out, and the amount that comes in.)
Also, batteries can add a huge expense to the system. While the photovoltaic panels have lifespans of 25 or more years, the batteries have lifespans far less than that. E.g. a decent marine battery runs around $100. At a guess, you'd need a couple dozen of them, and would replace them roughly every 5 years (wild guesses by me).
Just came back from some party. Lady approached me and tried to upsell me solar panels for my home. She said that it's a 20 year lease at 65$ a month. If we sell the home, the panels stick with the home and we aren't hooked for the lease. Gave her my email and she's going to send me some more info.
Anyone know anything about solar panel? Any helpful information would be nice.
Questions off the top of my head are..
Who is responsible for the panel if one of them breaks? Twenty years is a long time, something will break in that time frame.
Does the solar panel store energy in a big battery for night use?
Can I realistically save money with solar? Solar needs to generate at least 65$ a month to cover the lease before I can start seeing a return. Is this feasible?
