Anyone have issues with their display flickering on x1900xt?
CRT flickering with 1900XTX. from the very begining and AFAIK it happens with all ATi atleast current generation cards.
Do you get this flickering? What's your setup, are you running a single CRT, or dual CRT? In the thread I linked in the OP, people say it's an issue when running dual displays, but it's not totally clear if that's the case.
You shouldn't get flickering with an LCD.
CRT's if you get flickering just raise the refresh rate as high as you can make it go.
Did you read the link i posted?
He obviously didn't.
It does seem that only some of us have that issue.
I'd like to think an RMA would fix it, but i suspect with my luck i'd end up with a card with even worse flickering.
BTW, no, it's not limited to dual displays either.
Interesting, so you get this flickering? How often does it happen? Does it happen while gaming?
Does RMA'ing ever fix the issue for some people? I'm trying to figure out if the issue is just with certain cards, or if any x1xxx card can have this problem if used in the right (or should I say wrong/unlucky) system config.
No flickering on my X1900AIW and a 19" Samsung Syncmaster 997DF CRT. I'm using the 6.6 Warcats w/ATT instead of the CCC. Running on a 460W Enermax PSU.
