are the traces ripped? i can't see with your picture.
if they are you'll have to scrape off some of the kapton until you get to metal and then solder a strand or ribbon of wire onto the torn sides. or you may be able to jump the torn area with a blob of solder.
Yea I tore everything.
I'm not seeing any real traces or possibly I tore them off completely. Sucks cause its a $5 fix but with the holiday I have no chance of getting anything quick.
Ooooh.....how big are the traces?
Bad things can happen if you short out a li-ion or li-poly battery.
