Anyone have a recommendation on a color laser printer/copier/fax combo?
Arkitech
I need to get a coper and fax for my home office,so I'm thinking of going with a combo unit that can also output color print jobs too. Any suggestions?
Also is it possible to send and receive faxes over the net even if I don't have a dialup modem? (I have a broadband modem)
Not for free, you will need to sign up at eFax.com and use your PC.
The all-in-one might come with software to work with eFax, if not you will need to use it as just a scanner when you want to fax something that isn't already on your PC (like a Word document).
