WinkOsmosis
Banned
I lost my chamois so I bought one at Advance auto parts today. Are they good?
yeah but that's a good thing.its just a gloriified squeegee
Originally posted by: TechnoKid
some walmarts sell a smaller version of the original california water blade. The cheaper imitation ones are the "california dry blade," and are made in china. The original california water blade is made in the usa. I don't know why the smaller version of the orig blade is still packaged in the dry blade china packaging. The difference i noticed is that the orig blade in the dry blade packagin doesn't have that hole to feel the blade. edit: the smaller one is a lot cheaper than the bigger one. i think the smaller one is like $9.84 whereas the bigger one is like $17.50. the blades are *almost* the same length, hoever, the handle is a different length.
Originally posted by: Amused
It works great, but as someone said, you HAVE to make sure you get the car completely clean. If any grime is left behind, it will gouge your paint.
Yes, that's the bad news about using it. But as long as the car and the Blade is clean then I would recommend the product. I usually just use mine on the glass now and the Absorber on the rest of the car.
An Absorber won't be any better if you still have dirt on your car, and the CWB is faster and always reusable.
