Anyone got time for a long physics problem?
TecHNooB
Having trouble working this problem out. I see bits and pieces but its hard to put everything together. Here's the problem. There's reading involved, sorry T_T;
I don't expect anyone to work the entire thing out for me, but it's worth a shot!
For some isotopes of some very heavy nuclei, including nuclei of thorium, uranium, and plutonium, the nucleus will fission (split apart) when it absorbs a slow-moving neutron. Plutonium-239, with 94 protons and 145 neutrons, can fission when it absorbs a neutron and becomes Plutonium-240. The two fission fragments can be almost any two nuclei whose charges Q1 and Q2 add up to 94e (where e is the charge on a proton, e = 1.610-19 coulomb), and whose nucleons add up to 240 protons and neutrons (Pu-240, formed from Pu-239 plus a neutron). One of the possible fission modes involves nearly equal fragments, silver nuclei (Ag) each with electric charge Q1 = Q2 = 47e. The rest masses of the two silver nuclei add up to less than the rest mass of the original nucleus. (In addition to the two main fission fragments there are typically one or more free neutrons in the final state; in your analysis make the simplifying assumption that there are no free neutrons, just two silver nuclei.)
The rest mass of the Pu-240 nucleus (formed from Pu-239 plus a neutron) is 240.002 u (unified atomic mass units), and the rest mass of each of the two Ag-120 nuclei is 119.893 u, where 1 u = 1.6610-27 kg (approximately the mass of one nucleon). In your calculations, keep at least 6 significant figures, because the calculations involve subtracting large numbers from each other, leaving a small difference. There are three states you should consider in your analysis:
1) The initial state of the Pu-240 nucleus, before it fissions.
2) The state just after fission, when the two silver nuclei are close together, and momentarily at rest.
3) The state when the silver nuclei are very far away from each other, traveling at high speed.
(a) Calculate the final speed v, when the silver nuclei have moved very far apart due to their mutual electric repulsion. Keep at least 6 significant figures in your calculations. In your analysis it is all right to use the nonrelativistic formulas, but you then must check that the calculated v is indeed small compared to c. (The large kinetic energies of these silver nuclei are eventually dissipated into thermal energy of the surrounding material. In a nuclear reactor this hot material boils water and drives an electric generator.)
(b) Using energy considerations, calculate the distance between centers of the silver nuclei just after fission, when they are momentarily at rest. Keep at least 6 significant figures in your calculations.
(c) A proton or neutron has a radius r of roughly 110-15 m, and a nucleus is a tightly packed collection of nucleons. Therefore the volume of the nucleus, (4/3)R3, is approximately equal to the volume of one nucleon, (4/3)r3, times the number N of nucleons in the nucleus: (4/3)R3 = N(4/3)r3. So the radius R of a nucleus is about N1/3 times the radius r of one nucleon. More precisely, experiments show that the radius of a nucleus containing N nucleons is (1.310-15 m)N1/3. What is the radius of a silver nucleus?
(d) You could make a careful scale drawing on paper of the two silver nuclei in part (b), just after fission, and label the drawing with the distances that you calculated in parts (b) and (c). If the two silver nuclei are nearly touching, this would be consistent with our model of fission, in which the Pu-240 nucleus fissions into two pieces that are initially nearly at rest. How big is the gap between the surfaces of the two nuclei? (If you have done the calculations correctly, you will indeed find that the gap is a rather small fraction of the center-to-center distance, which means that our model for the fission process is a pretty good model.)
How the problem is worded, it sounds like they want you to assume that all of the energy from the decay becomes potential energy between two positively charged nuclei. Use energy conservation to find both v and the distance between the atoms right after fission.
msparish can you elaborate? Like how am I supposed to start the problem, what are the steps, etc. I just need a bump in the right direction. I'll do the calculations myself =o
The energy comes from the loss of mass between the fragments compared to the original nucleus.
E=mc^2
Relate this to kinetic energy to find the speeds of the fragments. As for the the distance between the fragments right after the fission, relate the energy to the potential energy of separated charges.
if this isnt homework why would you attempt such a problem?
if this is homework... do you really expect help from ATOT?
I might suggest Posting this in HT...
GOD my head hurts from just reading the problem.
