Anyone good with physics? Physics Problem
xvdarkyvx21
394
Can someone help me out with my physics homework? I need to answer this question and it deals with interference. Thanks.
"The coherence lenght of a wavetrain is the distance over which the phase constant stays the same. An atom of a light source emits coherent light for 10 ns. Calculate the coherence lenght of this wavetrain. c = 3*10^8 m/s"
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
I can't read that. can you unhighlight it?
ones3k
Banned
Aug 21, 2005
444
sure just plug it into this equation coherence = c^2 + e^(sqrt(ln(pi))) + c*sigma(i = 0 to infinity)(2/i^(1.002)) + integral(from 0 to infinity) (12424/x^2) + abcdefghijk/sqrt(z) + dslfksldkgsd
easy
drinkmorejava
3,567
7
i just took the AP Physics test, there was only like one question on anything about light phases. In otherwords, no one cares.
ArJuN
2,816
I know some physics, atleast I'm taking it now. E = mc^2 is all you need to know. seriously. plug everything into there and you're good to go.
wtf is a wavetrain btw?
Hepafleb
47
This part makes sense....
but this doesn't
Eeezee
9,922
If it's a phase constant then it should always stay the same ;)
Born2bwire
9,840
Heh, but it's only constant for the 10 ns of light that was produced coherently. Seriously though, this is probably the most convoluted way you could state a d=r*t problem that I've heard.
