If this data is from user input, then I would absolutely verify that it is a valid date; however, if not, it's usually not necessary. By the looks of your sample data it looks as though it's probably coming from an outside system (e.g. accounting perhaps?) or something, and in which case you can generally assume that the data is within the appropriate constraints.
