- Dec 8, 2003
- 12,696
- 1
- 0
This receiver that I just bought today has a plethora of connectors on the back. It has right and left RCA connectors for aux, phono, tape decks, and more. The weird thing is, all the RCA connectors are single conductor- nothing on the inside of the barrel, just the outer ring. i.e. the tip of an RCA cable will not be connected to anything. However, there is a screw terminal marked 'ground' mixed in with all the RCA jacks, so I assumed that that's where the missing conductor is. I just spent half an hour soldering up a minijack to dual-RCA and ground cable. So I've the outside rings of the RCA jacks connected to left and right positive, and the negative coming through the ground screw. Apparently, this is incorrect. Anybody have an insight?
