Originally posted by: Viper GTS
Originally posted by: brblx
how is heat output a negative of LED's? they produce next to zero heat, don't they?
No, they produce a ton of heat. The high output models need major heatsinks.
Viper GTS
Clarification: LEDs produce WAY less heat than incandescent / halogen, but they still produce heat. Big bright ones (like you'd use for a headlight) do need heat sinks.
I don't know if I read it or heard it at a talk by Cree (LED company) I attended in school a few yrs ago, but they said that a HID headlight has about the same efficiency as an equivalent brightness white LED.
The problem is that true white LEDs do not exist. They are typically super bright blue or violet LEDs that are coated with a phosphor that fills in the needed red and green colors to make the blue+green+red into a white looking light. This is why many white LEDs have a blueish cast to their color.
---edit---
I just reread the OP & noticed this is for a MOPED. I'd wonder if you could just string up a few white LED bicycle or hiking head lamps in some kind of package for this application. I guess you don't need a seriously bright light like a car...
Something like this might work:
http://www.ledsupply.com/creemce.php
But they are pretty darn expensive ($35 + heatsink / reflector package) if you need more than one!
