anyone ever have a portable USB flash drive fail on them?
edprush
2,541
I always felt that the thing was getting banged up too much against my keys.
It's a 128mb Lexar. The light still comes on when I plug it in to the USB port but the PC doesn't recognize it.
Heisenberg
10,621
Not me, but a friend of mine had one die on him. Nothing would happen when you plugged it into the USB port.
edprush
2,541
The light on the flash drive lights up but Windows Explorer doesn't show the drive.
eigen
4,000
I had the same model you did.It failed.
edprush
2,541
Could my not being able to access the files on the USB jump drive be due to me not 'stopping' the device before I removed it last time?
dullard
26,196
4,869
Yes they can and do fail. They have a very short lifetime (maximum number of writes). But more often when I see this problem, it isn't the drive's fault. Windows sometimes gets messed up. Try it on another computer. If it works, then uninstall and reinstall your USB port drivers.
So
25,923
17
Nah. I've had that cause it to recognize and demand to format the drive, killing my files, but it didn't kill the drive itself.
DivideBYZero
24,117
Yep. Recently had one lock the host comp when inserted and then produce odd error messages from which the comp would take a very long time to recover.
0roo0roo
64,795
84
its solid state.. unless u break some connections it should be fine.
any way of measuring the number of writes?
edprush
2,541
Format your jump/flash drive or your hard drive?
dullard
26,196
4,869
there must be some type of data recovery service out there.........
Have you tried in in another computer yet?
Kelemvor
16,928
8
I've never had one stop working. Use it every day and it's just on my keybhain but only with one other key. Hav one of rhe Cruiser Mini things...
Dubb
2,495
my lexar 256 died after about 8 months. same kinda problem. Couldn't format or anything, and tried it in several computers.
JoeKing
Originally posted by: CadetLee
Mine hasn't failed yet either (256mb PNY attache)
:thumbsup: these things are built to last I think. Mine has even gone through the washer and dryer a few times.
