Anyone else have sound problems with Fox on American Idol only?
Yep, watched it with the wife, and had the surround system on.
When AI was on, there was no center channel signal, only when I was watching the HD channel. Picture was great.
Commercial comes on, center channel works.
Switch to the non-HD channel, center channel works.
Any other station, center channel works.
AI comes back from commercial, center loses signal.
AI goes off, Skating With Celebrities comes on, center channel works.
Anyone else have this problem?
BTW, I'm in NC on Time Warner cable.
And is it me, or was Paula Abdul smashed or doped up tonight?
I used to do tech support for Time Warner cable. Call them, maybe you'll get ahold of someone in Wyoming. I'm sure getting told that it's tough ****** because we're a horrible company will be easier to bear if its comming from that far away. Offshot you'll get Canada as well, so even better!
Not sure it was a TWC problem. I actually think it was Fox. TWC is simply relaying the signal they get from Fox....my center channel worked fine on anything but the actual show. That makes me think it was a network feed problem, rather than the cable company.
I've had this problem with Fox before, too.
