Anyone Do Small Engine Repair?
olds
50,113
775
I was given a front tine rototiller and the recoil starter doesn't work. The rope assembly portion is fine but the clutch doesn't engage the motor.
Is this an easy repair? Are clutches generic?
Part:
pic
crab
7,330
19
Very easy, it just spins off. Knock it gently with a mallet and it'll unscrew. Pop that cover off and check it though, theres only a few ball bearing that are pushed out to engage those two pieces. Theres not much to go wrong though, so I suspect they may just be stuck. Do not grease them...you'll see why. Thats a briggs & stratton part any hardware store or lawnmower shop should have.
olds
50,113
775
Thanks guys.
I assume the threads are left handed?
slag
10,473
yep, normal left hand threaded. I wouldnt even remove it, just pop the black cover off (its pressed on), and remove the 4-6 ball bearings there.. Spray the inside down with brake cleaner to clean up the gunk and put the balls back in it.
They dont really go out often. They are a simple mechanism, metal on metal, and really have no wear parts.
skyking
22,705
5,829
:thumbsup:
It gets gummed up with dust usually.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
That appears to be from a B&S engine. This is an easily replaced part.
<edit>
oh, and no they are not generic. You will need one for your engine. Though there are not many kinds, probably a total of 10 part numbers for hundreds of different engines.
olds
50,113
775
It's a 5 HP Briggs and Stratton. It's mounted on a Yard-Man Earthbird 5030-3 Rototiller.
Evadman
Feb 18, 2001
30,990
hell, I probably have 10 of them in my shed then.
