Anyone built a passive water cooler?
Mark R
16
Just wondering if it would be possible to build a passive (gravity-pumped) water cooler.
Has anyone managed to do this for CPU cooling?
What size tubes did you use (I'd guess you'd need at least 1 1/2" diameter), and what type of radiator did you use?
Ayah
2,512
Somehow I doubt this would be possibly. You'd need a mechanical pump at least. The MCP350s are pretty quiet ones.
Something like an Apogee, 1/2" tubing, The biggest freaking radiator you can find (Car radiator would be good).
Gautama2
1,461
If your looking for passive water cooling you could fill your case with vegetable oil like the folks at toms hardware did a while back.
Mark R
16
Originally posted by: 0roo0roo
gravity pump?
Hot water is less dense than cold. Gravity pulls the cold water down below the hot water.
Arrange a loop so that heat source is at the bottom, and heat sink is above it, and gravity will generate a circulating current drawing heat from the source to the sink.
This principle is well established - it's used in domestic hot water systems. The furnace is in the basement or ground floor - but hot water storage tank is on an upper floor. Gravity moves the hot water from the furnace to the storage tank, and the cold water is drawn back down to the furnace.
Gautama2
1,461
gravity pump?
Its not gravity, gravity pulls mass. The speed of the particles doesn't affect the mass. Convection causes heat to rise.
Navid
5,053
Heat does not rise. Heat is energy not matter.
A hot fluid rises because it is less dense than the cold version of the same fluid. It is gravity that causes the colder, hence heavier, fluid sink to replace the warmer, hence lighter, fluid.
KBTuning
357
i dont think you could make the fluid at the top cold enough for this to work... it would just heat up everything and then overheat... that is unless you had some sort of ubercooler on the other end...
CurseTheSky
5,401
It could be done, but it wouldn't cool well unless you let the liquid cool OUTSIDE of your system. The Zalman Reserators are good examples of this.
Keep in mind, though, that you're be relying on your processor (or other components) alone to move the liquid. It'll be moving much slower than in a pumped system, and most likely be cooling less efficiently.
beemercer
817
I remember seeing a system that worked by hot water rising to the top, and the cool water sinking (fully passive) but the cooling performance was terrible.
Also if you live by a stream you could route the water into your house, into the waterblock, and then back out to the stream. This would rely on the flow of the stream to pump the water through the system.
CTho9305
9,214
Wouldn't something that expands/contracts more be better than water? They use alcohol and mercury in thermometers, so maybe one of them.
TheRyuu
5,479
14
I can just see the headlines.
"Man killed from mercury vapor trying to cool his PC"
..."dumb ass"...
:D
I really don't think Passive Cooling is worth it.
You can still build a very quiet PC with something like some Yate Loon fans on the Rad and the same in the case (so it'll be very quiet).
MoonglumWoW
33
I don't think it would be possible to use a GRAVITY pump for cpu cooling. A passive water cooler for CPUs usually refers to not needing a fan and/or radiator for cooling, but an ELECTRIC pump is always required to move the coolant. There are lots of passive water cooling articles to search for on overclockers.com, and you can pay particular attention to the issue of "flow rate" through the system. In testing, even the minimal flow rates would not be possible with a convection system. Some type of pump, mechanical or electrical, would be needed.
andy04
999
I agree, convection can be used to circulate the fluid but the problem is that the temp difference between the hottest and coolest fluid should be high for the flow to work effectively and you cannot let the temp on your CPU rise to that level therefore it cannot work.
One possibility is to use some liquid much thinner that water... like spirit then again that will be dangerous...
Bow down before the Nature !!
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
"IBM has also put a liquid cooling system to work in some of its servers. But its system is passive, meaning the liquid isn't cycled round by a pump; instead, cool liquids sink, then rise when heated up, to be replaced by falling cool liquids."
Source. I was doing some research, and I thought you might be interested in this....
aigomorla
21,053
3,538
there have been many attempts at making a passive watercooling system. Problem is when you try to overclock, the flow of water isnt fast enough to keep up with the raising heat from the cpu.
But its not at all impossible, XBOX 360's have been cooled passively, but it still required some sort of pump and a passive heat exchanger.
Watercooling without any flow and using convection to force water up and down however would be almost impossible. You would need to L neck the water from the cpu straight up and have absolutely no obstructions, it would be more messy then its worth.
This guy is absolutely correct. You would need to use a spirit, but each time u pressed that on button, u risk blowing your machine up along with half your room. :p
Smartazz
6,128
Or you can get a Zalman Reserator.
aigomorla
21,053
3,538
and risk masive pump failers that a lot of owners have? You can google it and find out yourself on my statement. I dont know about the new one tho, but id stay alway from the old one.
andy04
999
ok... in case you missed it, we are talking passive here. This bong has 2 pumps and a Fan - definitely NOT PASSIVE.
