anyone actually measure comp wattage with a power meter?
draggoon01
858
for long while still i see people debate power usage of their computer. especially with respect to what size psu they need for their comp. so i was wondering if anyone actually has a power meter or similar means of actually measuring the wattage of their comp and could post the results.
what would be especially helpful is if the person would include total sytem specs, and power draw during (1) idle and (2) gaming/video-encoding/something-cpu-intensive.
(although of course if someone reports xyz watts max draw, that doesn't mean you only need xyz power supply exactly)
Lonyo
21,938
There was a UK PC magazine that at least used to do that. They did under "normal" conditions I think (not quite sure what that means), and during standby. The readings were something like 80w for most when idle, and 250w for most at other times.
draggoon01
858
do you remember what the system specs were?
no one has a power meter and, or already, has measured their system in all of anandtech?
bozo1
6,364
For your experiement, you need to know the power draw on the different voltage rails - 3.3V, 5V, 12V - not what the total draw of the entire system is. A powersupply is useless if it can't provide the amount of current needed on any of the 3 rails regardless of the overall total wattage rating or actual total power draw.
draggoon01
858
if i wasn't clear, then excuse me. i was actually just wondering the total power draw of modern systems under idle and stress.
bozo1
6,364
Ahh. I did it many years ago and don't even remember the results, even though they wouldn't compare to todays systems. You have to use either a clamp-on ammeter that reads the current though the power cable or connect one inline with the cable.
Lord Evermore
9,558
Jerboy did it once. His PC came up to 90W but I'm not sure if it was idle or not. Not a 2GHz machine or anything, but not a Pentium 100 either.
0roo0roo
64,795
84
yup, surprising no techie has measured this. would be nice to know. esp for these high clocked athlon/p4's
Lord Evermore
9,558
Not all techies are electrical engineers; obviously most of the "techies" that are hardware enthusiasts actually think you need a 400W PSU to handle a minimally loaded PC. For those that would like to test it, not many want to pay 40 bucks for a device that they'll only use once. It's easier to just read the specifications of the devices to see what their loads add up to.
Mark R
16
I've done it, using devices that most of you will have at home: an energy meter (kindly installed by the electricity company) and a stopwatch.
For my 1 GHz Thunderbird Athlon system (256 MB RAM, Geforce 2 GTS, 2x HDD, CD-RW, DVD-ROM, SB Live) - power consumption is about 90 W at idle (empty windows desktop) - rising to 125 W when at max CPU load (e.g. Quake 3). 17" monitor was an additional 85 W.
A low-end Celeron system (Celeron 766, 256 MB RAM, i810 integrated stuff, HD, DVD-ROM), consumption was 50 W idle, 55-60 W full CPU load.
Don't forget that most PC PSUs have an efficiency of about 70%. So, in the first example, at full CPU load, the Mobo/CPU and drives were drawing about 90 W from the PSU.
glugglug
5,340
Most decent UPSes have a port to connect to the computer to monitor power usage, # of spikes on the line, input voltage variance etc. Usually through a 9-pin serial port. You can then generate nice graphs of your computer's power usage.
