deadseasquirrel
Looking to do load-balancing between 2 different MPLS networks, both terminating into the same router (28xx). Not looking to do cost low/high... want to share the load between the two networks, but, yes, have it fail over to the other one if either one drops. There's about 200 sites.
Is there a way to set it up so that it's dynamic, based off of load, or is it necessary to manually set up the routes so that half go through one MPLS network and the other half on the other MPLS network (with each using the alternate as a backup)?
