I'm in need of a large/cool render job that is compatible with version 3.1g. I will be using it with a parallel version of POVRay in a demo for my research. I'm looking for something that will take about 15 minutes to render.
I bit my teeth on POVray back in the day, so bump for you 😀 One of my first major programming projects was writing a DOS-based 3D video game system using POVray as the raytracing engine. The only snag I ran into was that I needed a 10ghz processor to do a fullscreen render 😉
