Anybody know if the engine from a third gen Accord (86-89) will work in a 2nd gen Accord (82-85)?
Viper GTS
38,107
433
My dad found a 1985 Accord LX with a blown engine (broke a timing belt, valve damage, etc.). I have a totalled but running 89 Accord...
Any chance that this would work relatively easily? If you don't know, how would I find out?
If so it'd be a cheap way to get a vehicle for now.
Zenmervolt?
Viper GTS
NikPreviousAcct
52,763
On an older car with not so complicated engine, it would be a piece of cake. But those complex little oriental cars are a PITA. Nothin like working on a vintage Mustang or 1940's Chevy :)
Good luck, Gregg. Your uncle should be able to help, right?
nik
NikPreviousAcct
52,763
Hmm. Well, the theory is all the same, though. If nothing else, go to a professional shop around here.
NW Auto Care
503-<no number, sorry>
Bassett Auto
503-645-8352
I recommend Bassett. I went to school with the owner's daughter and have had work done there. He doesn't dick you around. He tells you straight up what's going on.
nik
Viper GTS
38,107
433
Mine (89) is a DX coupe, the other is an LX... Unsure what body style it is.
Viper GTS
brtspears2
8,660
Heh, on a unrelated note, the hood of an 85 accord goes up like an expensive sports car instead of a "normal car"
Viper GTS
38,107
433
You mean it hinges at the nose of the car?
Viper GTS
brtspears2
8,660
Viper GTS
Yes that ... whatever the name of that style is called.
NikPreviousAcct
52,763
Viper GTS
nose hinge instead of windshield hinge?
:p stabbing in the dark here :)
nik
Eli
Super Moderator | Elite Member
8
I don't know the answer to your question really, but you could probably figure it out realitivly easy.. find the model# (I believe its on the engine block) and other information.. like serial#...
And then search around online... perhaps see if you can find sites that sell the "same" engine for use in the model years you want...
shrug.. hehe
