Originally posted by: GamerExpress
Originally posted by: Apex
That epson is a pretty good unit. I'd definitely take it over that BenQ DLP.
I guess you haven't read the diference between DLP and LCD for projection use in a home theater application.....Go for it then get the Epson.
Actually, I have read that ancient article you linked, thanks.
I've also owned 6 DLP projectors, 5 LCD projectors (including 2 Epsons, one with Micro Lens Array, one without), and currently have a D-ILA/LCOS unit which has many advantages over the other two technologies.
The BenQ PE7700 is a reasonably good projector, based on the HD2+ DMD. 1100 ANSI lumens (about 400 lumens calibrated), 2500:1 on/off contrast, and 5x speed 6-segment colorwheel. It has pretty poor brightness uniformity, though reasonably good colors for a DLP. The BenQ processor it uses is reasonably good at scaling, but up and down, but poor at deinterlacing (not a big deal).
The Epson EMP-TW600 is one of the better LCD projectors, based on their latest .7" panels with MLA (multi lens array) technology to help reduce screen door effect. It's rated at 1600 ANSI lumens (closer to 800 calibrated), 5000:1 on/off contrast, and the same 720p native resolution as the BenQ. It has much better brightness uniformity, and richer, more saturated colors (though they still look natural instead of cartoonish). Part of that is due to its 10-bit internal color processing, part due to LCD's better color ability. It's also marginally quieter. You also get the benefit of both vertical and horizontal lens shift, which makes placement much easier. Scaling is not as good as the BenQ, but deinterlacing is better.
So, please do tell us how that article explains why the PE7700 is better than the EMP-TW600.
