Just a small update for all you Sandy Bridgers...
Finally completed the the SB build this past Sat.
Ran into problems trying to load Win 7 onto the SSD. Took about 2 hrs in which there was enough of a "power-on" window that Win 7 finished loading. Was getting power-ups & power downs. Suspect it was a bunch of things until I remembered that I replaced the EVGA 8800GT card in the Q6600 box with an EVGA 460, whiched solved the shut-downs I was having with the Q6600 at the time.
Picked up a Zotac 470 card at the local MC and after adj cables because of this beast of a card and fired it up. This solved the startup-shutdown shuffle so currently pc is humming at 3.4ghz (no o/c yet) and d/l'ed a ton of Win 7 updates plus ESET Nod A/V, Cpuz and PC wizard 2010, etc.
The cpu is being cooled by a Zalman 9900MAX - it looks like a bagel, the 135 size fan being the "cream cheese".
On Jan 17th at 18:58 UTC fired up the GPU to run 6.30r2 Fermi F@H s/w - results so far:
Project Min/steps
6805 1:38
6805 1:39
6806 1:30
6806 1:30
6806 1:30
6806 1:30
6805 1:38
for a total of 9,232 on a non-o/c'ed 470 gpu
The reason for using the gpu first is that I'll need to learn how to safely O/C this new pc since it's the first time I'll be messing with that and to look up what I need to do to start up this box doing BigAdv (already have the passkey from stanford)
Until the next update...
