Has anybody ever ordered a no-OS system from Ascendtech? I know they have a pretty good reputation on resellerratings.com, and I have read positive references to them in this forum, but was wondering about their matching and quality of components in their pre-built systems.
For example, I was looking at their Phenom II X3 710 systems:
http://www.ascendtech.us/Custo...asp?kc=DTPCPHIIX371001
It's $245 shipped now, and I think I saw it for $225 a few days ago (same config I think).
It seems almost too good to be true. I assume the case is really basic, but typically do they use ones that are equal to the rest of the system and have enough amenities not to be awful? (think the case fan is extra.) And, the HDD, memory, and to lesser extent cd-rw, do they use reasonably decent ones?
They don't even give a wattage rating for the default PSU, unfortunately.
(Memory is a little low on this particular config.)
Alternatively (and this is another question).. if I build myself instead of ordering from Ascendtech, I might use my old case. It's a Micron Millenia case (http://www.pcworld.com/reviews...w/millenia_ts_pro.html ) that houses the 1Ghz system in my sig (the cpu and mobo are stock for the case I think). I believe so far it's ATX (will have to confirm). Does anyone know if it will be good enough to house the Phenom triple core above, or a Phenom II X2 550, or an Athlon 7750 Dual-Core? There's no fan in the front, and the one in the back is ~75-85mm (I'm assuming it still runs well enough, it's about as loud as when I got it secondhand 4 yrs ago, and airflow out the back, just feeling w/my hand, doesn't seem worse than that out the back of the newer Dell dual-core system in my sig). I don't plan to do any overclocking atm, and don't plan to add an add-in videocard yet (may eventually add a 4850).
Many thanks for any help!
