Originally posted by: SagaLore
Consider this...
Put the log home on a
solid and insulated basement. In the middle of the basement, put in a
wood or gas stove, with the pipe going straight up through the house inside some ductwork and branch off ducts and vents to heat the house.
In your bedrooms and bathrooms, put up your standard insulation and drywall. And like someone else said, put in some nice insulated windows. You should look into
this insulating paint additive and see if it can be added to wood stain or transparent glaze. You might be able to coat both sides of the wood logs with this stuff.
And someone else pointed out wind still creeping through - one good building strategy is to plant wind supressing trees on the windy side of the house.
