When I click on the shortcut to star the WinTV Scheduler program, it appears to start up - the splash screen displays, a button appears on the Task Bar, and the program shows up on the task manager under both applications and processes - but the actual window never appears. If I boot into safe mode and try it, it works fine. That makes it sound like a program that runs at startup is causing the problem, but I've tried stopping all of them (one at a time, using StartupCPL) and that didn't fix anything. suggestions?
System specs: Windows XP Pro SP2, WinTV-PVR250 using the latest drivers (I forget the exact version off the top of my head)
Nate
Nate
