Any way to speed up IE5 scroll speed?
spencer
I use netscape most of the time but lately I find myself using IE5 more and more because netscape won't display a website right or not display it at all when IE will. Is there any way to speed the scroll speed up using a wheel mouse? Man, IE5 scrolls slower than hell and it bugs the piss out of me.
Gorgonzola
1,300
in the options turn "smooth scrolling" off, and it will scroll a little better. it still wont be as crisp as netscapes. in IE, you basically have a choice between "smooth-slow-motion" and "fast-jolty-shite", in my opinion anyway :)
Mday
18,647
the only option you really have is to have the program that runs the wheel scroll more than one line at a time. or press page down.
KarayaOne
26
Well, actually, there is another way...
Install Tweak UI from the Windows 98 CD. (If that's what you're using). It allows you to define how fast your wheel scrolls.
