Picked up a Coolermaster Sickleflow yesterday to replace a fan with a broken blade in my Noctua DH14. The computer store supply was limited to the Coolermaster, they didnt' have any Scythe gentle typhoons or yate loons in stocik.
Attached it to CPU HSF and plugged right into the P9x79 cpu pin header. The fan runs at 1.8k RPM continuously, and there was nothing I could see in the BIOS to change the speed manually, as well as through the ASUS monitoring software.
Without a fan controller, do I have any options for regulating speed on the sickleflow? 2k RPM is so loud, and I don't think it needs to run at that speed to maintain nice temps, 29-34 idle, 57-62 max load. (specs in sig below).
Thanks in advance
Thanks in advance
