has anyone found a way, it won't recognize it of course. if I set the bus to 133 * 10.5 and the voltage set propperly shouldn't it work? or is that too much OC for the chipset?
It should work, bro. HardOCP had theirs' at around 150 FSB (300 effective). But yes, you should be able to run it on any FSB, including 100. Just set the FSB to 100 and the multiplier to 14 (if it indeed has 14; may require a bios upgrade).
<< It should work, bro. HardOCP had theirs' at around 150 FSB (300 effective). But yes, you should be able to run it on any FSB, including 100. Just set the FSB to 100 and the multiplier to 14 (if it indeed has 14; may require a bios upgrade). >>
Hrm thanks for the good news
I tried it real fast on my way out the door with no post @ 133 times 10.5, so maybe it's the voltage whackin me up, I didn't have time to look it up. I'll try 100 times 14 for the sake of stability.
I notice the same BIOS applies to the original, A and E Kt7 so I'll give that a shot too.
well, my board won't do 133, or a X14, but I got it to run at 110X13 so that gives me 1430 somethin, I guess that will have to do until I get a board that supports it better
